Tractor Talk Discussion Forum
OT:chlorinating rural wells?
IaGuy
05-12-2005 18:35:16
Anyone have experience with automatic chlorine tablets being dropped into the well for reducing the red stuff? My plumber guy says there is a new design unit made in Iowa that works well for this. He says the chlorine action causes the red stuff to granulate and drop to the bottom of the well. At $795 installation and $40 per gallon jug of the pills x unknown rate of use, I think I would like to ask around a bit. This forum pretty knowledgeable about rural things, thought I would ask!
workhorse
05-13-2005 05:18:44
 Re: OT:chlorinating rural wells? in reply to IaGuy, 05-12-2005 18:35:16
I have seen down the well vidio of chlorine tablets laying undisolved on the bottom. It seems in some cases the tablets don't disolve unless the water passes over them. One step in the shock chlorinating process to remember is to save 10-15 gal of treated water to dump in the top of the well after the pump is shut down. this forces treated water through the well screen to the outside of the casing killing bacteria that may be hiding in the aquifer.
MarkB_MI
05-13-2005 03:47:26
Before you spend money on an automatic chlorinator, first see if chlorination helps. You can shock your system with Clorox. Here's how, if you have a submersible pump with a pitless adapter.
1. Switch your water softener to bypass, as Clorox at high levels can trash the resin bed.
2. Take the cover off your wellhead. Dump some Clorox in. There are formulas on the web for determining how much, but I'd just dump in half a gallon to start; you can always add more.
3. Take a garden hose and use it to run water down the well. Stop when when you can smell chlorine coming from the hose.
4. Open up the cold water taps in the hose until you can smell chlorine in each, then turn them off.
5. Open up the hot water taps and run them until you can smell chlorine. You might as well turn off your water heater, since you'll flush it out later.
6. Leave the house for a few hours.
7. Run your taps until you no longer smell chlorine, or at least it's mostly gone. There will probably be some residual chlorine for a few days. You can turn your water softener back on once the worst of the smell is gone.
If your problem is temporarily fixed, then you might be a candidate for the chlorinator.
(I thought I was going to have to do something similar, until I figured out that I just needed to swap out my water heater anode to fix the rotten egg smell in my water. I'll post a message in tool talk on that.)
Ibby
05-13-2005 03:13:58
If the red water is caused by iron bacteria, chlorinating the well should stop it at least for a while. The trick is to get the chlorine ALL the way to the bottom. Dumping it on top may nopt let it reach very far down.
I cleared up my father-in-law's well by mixing a gallon of Chlorox into 10 gallons of water. I coulped together enoufgh garden hose to reach the BOTTOM of the well (almost 200 feet) We fed the hose into the casing until it hit bottom and he started pouring the chlorox mixture into the hose as I withdrew it. We still had chlorine left when it was all out, so I fed it back into the well as he kept pouring it in.
After sitting overnight, he pumped it out until no chlorine odor remained. It worked so well that he was able to remove all the filters, precipitators and other gimmicks he spent so much money on in a vain attempt to treat it.
I caution that this might not work for everyone. This case was an iron lined well that had sat for 20 years. If the red is caused by OTHER than iron bacteria, or if the bacteria is in the aquifer, this won't work. Good Luck!
old
05-12-2005 21:16:01
In my area they would tell us to pour a gal. of bleach in the well and turn off every thing over night then pump out all you could for a couple hours and then just use it
another doug
05-14-2005 03:28:50
 Re: OT:chlorinating rural wells? in reply to old, 05-12-2005 21:16:01
My Dad used Old's method once, he didn't follow the directions that the guy at the plumbing shop gave him, when he reported back to them, they just smiled and when he said he poured a whole gallon into the well.No biggie,,,,just let the water run till it doesn't smell like bleach,today, the water still smells awful, maybe sulfur, yuck, but our well and the one at the barn tastes great, oh....we still have the iron problem, and use a water softener for that, but the bleach didn't help his problem , so it's gotta be something else...what are you trying to improve upon? iron in the water? or taste?
IaGuy
05-15-2005 10:38:57
 Re: OT:chlorinating rural wells? in reply to another doug, 05-14-2005 03:28:50
The iron in the water continually clogs the #60 (.010 opening) filter to my well water fed heat pump furnace, forcing it to switch to the much more expensive backup heat grid. I was planning on adding one or two more filters in paralell with the existing one so that I could go on a winter vacation without that happening. Taste is ok. Smell is ok since I took out the anode from the water heater. The red sludge nearly plugs the hydrants outside. The well has been "shocked" twice with powdered chlorine and "blowed" once. The stuff seems to be in the acquafer. I may have to run the furnace feed through the water heater which seems to totally remove the red stuff from the rest of the house water. I appreciate the comments very much. IaGuy
