Tractor Talk Discussion Forum
intermitent miss (sputter) no load ONLY!
rasputen
01-08-2005 19:56:44
I am trying to find the ELUSIVE cause for no-load sputtering on my '47 8N.
This is a common problem with 9N,2N,8N flatheads....and yes I have both searched the archives (a LOT) and posted on the N board.
NO ONE posting _Knows_ the cause!
This "sputtering" is at idle (400rpm) & some at a slightly higher idle with NO LOAD. Any slight load causes the sputter to completly disapear! Also will sputter down hill, clear up after level (float is fine).
Several N experts recite begenner trouble shooting tips like rursery rymes & some have just said it is the nature of the beast, they all doit. It really is just a pet peeve as it is my only problem left after 15 years of having this tractor.For years I assumed! it was valves, till I pulled the head & valves & replaced & lapped them.NO CHANGE.
I suspect this is a cam/gear slack/dist timing issue....just from the no load only apearance.
Hopeing someone here can shed some REAL light other than saying something over & over real in 'cute'venacular.
I have done much work including,
MMO for freeing valves,lapped valves,rebuilt carb & re-checked again & again (including lapping the halves),installed Petronics Electronics Ignition, re-replaced the AL437 plugs (gapped .025 & tried .030,.035). The front mount dist has new bushings & weights are free & working, new solid core plug wires. Several good coils.Timing is correct & rechecked.
Thanks for all replys!!!!
01-10-2005 18:02:15
 What I've learned. picture of Henry in reply to rasputen, 01-08-2005 19:56:44
third party image
^Henry^...last night....built in '47 but'48 model
SN 34055.
Thanks to all that took time to reply, many more than I expected!!!
I think many were good replys, just things I've already eliminated.
From here I will drill & tap my replacement manifold & buy a vacuum gauge. If that helps I'll report back what I find.
If that gives no help I will (soon I hope) do a complete valve job w/new valves,1 piece guides & all the other parts. I am planning (Iza Gonna) rebuild anyway, just waiting to get it together to do it right 1 time ...stem to stern.
I kinda hate to rebuild cause he runs so good, but I really want to paint ole Henry & engine rebuild is a big b4. That & steering are about all the major stuff left.
Thanks a lot, you gave me a lot to ruminate on.
brianh
01-10-2005 10:05:15
 Re: intermitent miss (sputter) no load ONLY! in reply to rasputen, 01-08-2005 19:56:44
Generally, problems like this that disappear under load are due to a too-rich condition -- that's why it disappears under a load. The fact that it occurs at a fast idle makes me think that it is aggravated by the overlap in the carb between idle and high-speed systems. Does running it without an air filter make a difference? (slightly leaner mixture). Have you tried lowering the float a little? Many small engines will do this same thing at high speed no-load when you have peaked the high-speed jet under power. Brian
rasputen
01-10-2005 17:27:25
 Re: intermitent miss (sputter) no load ONLY! in reply to brianh, 01-10-2005 10:05:15
Brian, Short answer is NO WAY!
It is not too rich. In fact plugs confirm as they are grey tan, idle adjustment needle is air, can open it up and problem gets worse/exagerated. I worked real hard on the carb to get it richer cause I felt if anything it was too LEAN. Many jet sizes tried & the float has been tried over & under the stated 1/4".
I am now convinced after many hours of carb tweaking from very rich to very lean that it is nothing to do with mix. Also all variations tryed, & standard spraying of WD40 everywhere possible around manifold/carb/throtle/choke.
Thanks for the suggestion
Tim Brake
01-10-2005 09:15:52
I have been told that new bushings in the distributor will cure the occasional miss problem. I don't know that for sure as my 8N does the same as yours. But mine runs great on top end so I'm not to worried about it.
rasputen
01-10-2005 17:29:45
 Re: intermitent miss (sputter) no load ONLY! in reply to Tim Brake, 01-10-2005 09:15:52
Tim,
I know I am long winded.
"The front mount dist has new bushings & weights are free & working, new solid core plug wires. Several good coils."
I 'heard' that one too.
Jerry/MT
01-09-2005 19:57:06
What's your timing look like? I mean with the engine idling, is your timing mark rock steady? If it's not, it could be wear in the cam drive of the distributor (you all ready took care of the worn distributor syndrome). Wear in the breaker plate/advance mechanism?
It could be poor mixture adjustment. I doubt that porting would do much good because Idle airflow is so low. Porting/polishing helps reduce pressure losses at high airflows, but that's not your stated problem. If you hook up a vcuum gauge and set the mixture to the highest vacuum level at a fixed idle speed that might fix it. Make sure that your governotr linkage isn't giving you some problem. That about taps me out with ideas.
rasputen
01-09-2005 22:00:54
 Re: intermitent miss (sputter) no load ONLY! in reply to Jerry/MT, 01-09-2005 19:57:06
Thanks,
Timing is perfect, no timing marks on a '47 8N.
Set it with dist tang, & it is dead on. Did not port or polish this one.
Will get vacuum gauge tomorrow if I can find one.
Gene Davis (GA)
01-09-2005 19:30:40
Weak valve springs can often cause a fluttering condition like this. Hook a vacuum gauge to the intake and watch for a jumping needle. That is usually a sign of valve guides worn and/or weak springs. Short out one cylinder at a time while engine is running and watch for the one that seems to be be making the exhaust fluttering sound(s).
rasputen
01-09-2005 22:02:08
 Re: intermitent miss (sputter) no load ONLY! in reply to Gene Davis (GA), 01-09-2005 19:30:40
Thanks Gene,
Will do!
Allan in Ne
01-09-2005 10:03:38
Ras,
Please, please, please do not take offence at this, but if you had bell-mouthed guides and then went in there and "lapped" your valves and seats, you have actually compounded the problem instead of helping solve it.
Lapping, without first having the valve in absolute perfect alignment with it's seat, is just "wobbling out the hole" more yet and is just 'adding' to the wear, so to speak.
Allan
rasputen
01-09-2005 10:25:10
 Re: intermitent miss (sputter) no load ONLY! in reply to Allan in Ne, 01-09-2005 10:03:38
Could be what happened...but...it was doing this for YEARS before I touched the valves.
I think I need to bite the bullet & do a complete rebuild anyway...at that time I will replace all guides & valves & have seats checked/replaced/ground by machine shop as needed.
No offence taken
Hermit
01-09-2005 07:37:26
Have you tried porting and polishing both the head and manifold exhaust ports? A slight misalignment could be causing a restriction or higher than normal back pressure to develop resulting in improper scavanging of the cylinders. This would leave a higher than normal level of exhaust gases to mix with the incoming fuel/air causing a lean mixture and possibly misfiring. When rpm's increase, exhaust gas velocity increases allowing for proper cylinder scavanging and the miss goes away. It's a theory anyway.
rasputen
01-09-2005 07:57:26
 Re: intermitent miss (sputter) no load ONLY! in reply to Hermit, 01-09-2005 07:37:26
Thanks Hermit,
I did do some light polishing on my other tractor, a 134 OHV 641 and it does not sputter. It could be the non OEM manifold.
961powermaster
01-09-2005 02:22:59
Hello and welcome to my world.
I have been fighting this problem for about 2 years. I can tell you that they don't all do it. Mine didn't used to do it. I have the exact same symptoms as you and then some. Mine will also sputter at half throttle and need some choke to run smooth. The only thing I have not done is a complete valve job. I am about to the point of ripping the motor out and doing a "complete overhaul". I think it is a valve problem. Mine used to hold back/run smooth when going down hill, not any more.
My problems started a month or two after I installed A sherman over/under in my tractor. I was in a rush to get it back together to get hay raked. In my rush I didn't get the metal air intake tube all the way in the rubber hose under the hood at the air filter. It pulled out sometime while raking hay, hence no air filter in line. It was not in dusty or dirty conditions. The miss/sputter did not show up right away. I can only guess the lack of air filter let some dirt or grit in and pitted the valve seats/valves and it has slowly gotten worse.
Alot of people around this area don't like the little ford 8n's. lots call them "farting ford 8n's" Well if they all run like mine does now I would agree. That's what makes me mad is knowing it can run great/smooth because I have seen it.
I also wanted to put a vaccum gauge on the motor but have not gotten around to it yet.
Hope you can find something. I am about out of options except a complete rebuild.
rasputen...tired of the s
01-09-2005 08:10:35
 Re: intermitent miss (sputter) no load ONLY! in reply to 961powermaster, 01-09-2005 02:22:59
Thank you 961powermaster ,
This is what I wanted to find out!!
I lapped the valves but did not do a complete valve job. Also wanting to do a full overhaul, just dragging my feet cause otherwise it runs great.
Alan in NE suggested a worn valve guide, I sure have some of them.
I feel your pain! Just feel much better knowing someone else out there is tired of the sputter also. Your comments about the farting fords could be why I couldn't get any well thought responses on the N board, except one person said they all doit! The gordian knott of the N's??
Thanks to everyone for responding. I'll be fighting this till I die or I get it.
You can be sure if I fix it I'll buy time on TV to tell the world. Ok, maybe only tell it here, but often & LOUDLY!!! *<80)>----rasputen
Willy-N
01-08-2005 23:43:28
Could just be a irregularity (burr? slitely plugged jet hole?)in the carb that anything above a idle corrects it. Slitest manifold leak very small and does not affect it power wise ect. spray some either near the manifold to see if it changes. Tip of one neadle jet worn down a little or seat worn a little, throttle pin loose a little with a little play ect. Just enough of a problem to effect the mixture some at a idle. Mark H.
rasputen
01-09-2005 01:22:41
 Re: intermitent miss (sputter) no load ONLY! in reply to Willy-N, 01-08-2005 23:43:28
Mark,
I have rebuilt the carb several times. All bushings & seals are new & no air leaks. Tried WD40. Retorqued the manifold & got excited when I found a stripped brass nut. Replaced & torqued all but no change. This sputter has been going on for 15 years w/ various upgrades not changing it a bit. Replaced the manifold a few back & fixed the inherent #4 exhaust deteriotion on block,no change.
ALL jets changed, inspected, cleaned, looked at with microscope ect....cleaned ALL passages with carb cleaner/air/guitar strings...even tried diferent sized idle jets to get richer mix as it is always a bit lean (TSX 33), changed my idle/air setup to get it right w/new jets but never any change to the idle sputter.Tried various economizer jet sizes & even plug/screw in economizer port where jet goes. All these changed the way the carb acted & setup to get it adjusted but never changed the sputter. Had no main jet at bottom of main needle,just empty hole w/no threads(???) (jet is under nozzle). Tapped the hole & installed correct main jet, this provides better main jet adjustment, but NO CHANGE in ANY operating range!!!! This carb is unbeleavably forgiving.
Tractor runs like a top!! Awsome power, just the anoying sputter intermittently at _NO LOAD_ idle or fast idle.
Allan in NE
01-08-2005 23:38:35
Ras,
This is just a thought; I've only seen this once before, way back in the 60s and your symptoms nail it to a tee.
Put a vacuum gauge on that thing; if the vacuum drops right when the sputtering is going on, but comes right back up when she clears up, I still think you have a valve problem.
Not a "valve" valve problem, but rather a sloppy guide. If it only does it just at that one, low, "just kinda off idle" speed.
The rotation of the cam is forcing that valve follower sideways, which in turn pushes the valve in it's guide just enough to "cock 'er", which drops the compression, & it makes 'er sputter. Any more speed and she then lifts clean and your sputter goes away.
To really check the guides, have the keepers and springs off and lift the valves just an eighth of an inch or so off the seats. This is the point of most wear and there should be absolutely no sideways play in those stems/guides.
Those guides really get ignored in those old flatheads
Allan
rasputen
01-09-2005 01:32:53
 Re: intermitent miss (sputter) no load ONLY! in reply to Allan in NE, 01-08-2005 23:38:35
Thanks Alan, I think I'll drill & tap my aftermarket manifold to do just that. Sounds reasonable, as I lapped them 3 or 4 years ago but did not do a complete valve job.
I did check & had "some" guide wear.Want to do a full engine rebuild & I DO mean COMPLETE! Just hate to not have this tractor running as I am way too attatched to it, (stoopid since I have another tractor as backup).
Thanks again for makin' me work so hard!! *<80)>
Gerald J.
01-08-2005 20:02:31
Set the idle mixture a little richer or leaner which ever clears the problem. Then if its not as good under load (which will have opened the throttle to run on the power circuit instead of the idle circuit), adjust by making the mid and power ranges leaner or richer in the opposite direction from the idle adjustment by changing the float setting. Raising the float level (closer to the flange) makes mid and power run richer.
E.g. refine the carburetor settings indirectly.
Gerald J.
rasputen
01-08-2005 20:11:46
 Re: intermitent miss (sputter) no load ONLY! in reply to Gerald J., 01-08-2005 20:02:31
Thanks for the reply:
Tried that! Even tried opening jets to get overly rich mix as the idle jet is air & can add a lot of air from where it is!
I can rich it up till it starts stumbling and almost dies. NO carb setting will correct the INTERMITTENT Miss. Very short miss, like it just missfires on 1 stroke on 1 cyl intermittently.
Carb is MS TSX 33. Carb has been worked over A LOT as in even several larger jets tried to correct a possible LEAN problem you described. Had problem for 15 years, clears with even slightest load!
Gerald J.
01-09-2005 07:17:54
 Re: intermitent miss (sputter) no load ONLY! in reply to rasputen, 01-08-2005 20:11:46
Still sounds like the idle circuit. What is the intake manifold? Is it a dual fuel and so hot manifold? Could the heat made for distillate be messing up the mixture between cylinders?
I have a '65 F-350 with the block changed to a 390 and some other 4 barrel carburetor. It sounded like it was rich at idle causing it to run poorly after a while, but actually it was running lean and the cure WAS raising the gas level in the float bowl.
Maybe you need to be sure the voltage regulator is set for 7.2 volts and keep the headlights on to give the engine a bit of load to let the governor open the throttle off pure idle.
Gerald J.
rasputen
01-09-2005 08:22:04
 Re: intermitent miss (sputter) no load ONLY! in reply to Gerald J., 01-09-2005 07:17:54
Voltage reg set to 7.2 & works fine.
Don't have exotic manifold, just 4 or 5 year old regular replacement non OEM Tiawan or somplace like that.
Don't think I want to run the lights even if that cures it, running the PTO in very cold wether 'fore it warms up gives it a slight load.(GL1)
Thanks for the response.
txblu..different approach
01-09-2005 03:19:20
Seems a 1 cyl miss is electrical.
One of my pet peeves is just that on a non-fuel injected gas engine. Runs fine but pffst intermittently at idle
The way I solve that problem is to install an electronic ignition with the high voltage coil option(Genessee works fine with their 40kv coil). Then I get some plugs [like old ones I run (ran) in my Dodge p/u] that have a deep snooz and set the gap to about .060. I always check the piston top clearance before I do this to insure that the plug will not interfere with TDC on the piston (Stick a stick down the plug hole and "find" the piston top, then measure clearance).
Puts out one heck of a smack and it's down in the combustion chamber where everybody can get a whif of it and she ain't a missin no mo.
Do every gas tractor I get as a matter of course upon arrival. Bonus..... ..... .no !@#$%^&*()_+ points to mess with!
Mark
rasputen
01-09-2005 08:17:10
 Re: intermitent miss (sputter) no load ONLY! in reply to txblu..different approach, 01-09-2005 03:19:20
Thanks Mark,
I do have EI but stock coil but it measures 25K+ on a spark gap tester (yes-outside the cylinder).
Good hot blue spark! I ran my AL-437's up to .040 but went back to shorter gaps TS'ing this while working the carb EXTENSIVELY!
I can try that eazy enought as I am running 6.5 compression at best.
Weirsdale George
01-08-2005 22:01:45
"Very short miss, like it just missfires on 1 stroke on 1 cyl intermittently."
Out of curiosity, have you tried to isolate which cylinder might be missing. If it always the same cylinder, it could be some sort of manifold leak (gasket or pinhole) on the runner leading to that cylinder. Sometimes spraying something like WD-40 on the manifold will uncover such leaks.
rasputen
01-08-2005 22:31:32
 Re: intermitent miss (sputter) no load ONLY! in reply to Weirsdale George, 01-08-2005 22:01:45
I have shorted each plug independantly, none seem to cure the symptom. All plugs slow it down but # 4 seems to really slow it down.
Still, no plug isolated the sputter.
steveormary
01-08-2005 22:17:21
One of my tractors(not the Ford) did that even after overhaul. Finally decided to replace ignition switch. Took care of that problem.
steveormary
It may be the nature of the beast.
korn_fed
01-08-2005 23:16:46
 Re: intermitent miss (sputter) no load ONLY! in reply to steveormary, 01-08-2005 22:17:21
I think it could be the nature of the beast. Have a MF35 (continental 134ci) that sounds/runs the same way. Never misses under load so i don't consider it a problem. I feel it is the crudeness of the carb, not exactly the precision of efi controlling the fuel mixture. Maybe even the exhaust system.
Ken
korn_fed
01-08-2005 22:53:39
Ken
rasputen
01-08-2005 23:01:35
 Re: intermitent miss (sputter) no load ONLY! in reply to korn_fed, 01-08-2005 22:53:39
Yeah, you may be right. I was just sittin' lookin' at the manifold thinkin' about those center siamiase ports & wondering about the exhaust baffles hotrodders add in v8 flathead fords.
For years I thought it was a burnt/sticky exh valve 'cause it will pop a piece of paper at the tail pipe. Been wondering if it is just inherent in the manifold design.
BTW: My 134 CID OHV Ford 641 does NOT have this problem.
Thanks.
rasputen
01-08-2005 22:37:10
Thanks Steve (or is it Mary)
Bypassed the New ignition switch several times looking for an easy fix. BTW been thru 3 switches in the 15 years I've been trying to get rid of this 'sputter'.
Also remember, it COMPLETLY goes away under any load!!! Even lugging in low gear at idle NO MISS.
Thanks again for the replys, been thru a LOT of things but willing to get all suggestions.
steveormary
01-09-2005 04:11:39
 Re: intermitent miss (sputter) no load ONLY! in reply to rasputen, 01-08-2005 22:37:10
rasputen;
It is Steve who works (lurks?)on the tractor board. The tractor I had the problem with was a 1952 TO-30. We used to think it was the leaded gas that would cause plugs to short out and miss. But it sounded better then the,nevermind.
steveormary
Bill in TN
01-09-2005 06:46:34
 Re: intermitent miss (sputter) no load ONLY! in reply to steveormary, 01-09-2005 04:11:39
Possibly not enough back pressure on the valves due to an open exhaust?
