Tractor Talk Discussion Forum
8N Generator
rwood
01-04-2005 07:55:55
After I replaced the original ammeter on my 8N with a current (no pun intended) model, one that has two poles on it, I noticed that the reading showed the needle in the negative area of the dial when running. I'm guessing that the generator needs to be polarized. Am I wrong?
xragman
01-05-2005 06:11:03
 Re: 8N Generator in reply to rwood, 01-04-2005 07:55:55
if this is an inductance meter ( no terminal conn.) wire thru loop. change direction you run wire thru loop.
john-Mi
01-04-2005 08:16:47
If it was correct before changing meter you probably need to change the wires to opposite way you have them hooked up. Then it will show charge instead of discharge.
