Tractor Talk Discussion Forum
Ford Tracker 9N
Ed Hall
10-04-2004 18:21:47
Can anyone tell me when checking the firing order do you count one from the front of the motor or the back. Can anyone tell me how to determine the year of a 9N Ford Tracker.
JoeK
10-04-2004 19:14:02
 Re: Ford Tracker 9N in reply to Ed Hall, 10-04-2004 18:21:47
No 1 would be front cylinder,1st one behind the radiator.Ford 9N serial no is on the side of the block(stamped)just below the head above the generator.That no will translate to yr of mfg,unless engine block has been changed out.
Oops
10-04-2004 19:19:32
 Re: Ford Tracker 9N in reply to JoeK, 10-04-2004 19:14:02
Number would be stamped on a flat on side of block behind oil filter cannister top and above starter.
RJ-AZ
10-04-2004 19:12:46
Front to back 1-4-3-2
rhouston
10-05-2004 08:23:18
 Re: Ford Tracker 9N in reply to RJ-AZ, 10-04-2004 19:12:46
musta spent too much time workin on VW's
Bob
10-04-2004 23:14:50
That's REALLY gone screw him up!
The correct firing order is 1-2-4-3.
Cylinders are numbered from front to back 1-2-3-4, as is the conventional fasion!
