Tractor Talk Discussion Forum
Mc Cormick W12 brake drums
JeanRay
09-22-2004 21:38:16
Can somebody tell me how I could remove the brake drums from that tractor. They are so sticked it is impossible to pull the tractor. The weels wont spin at all. I removed the nut retaining the drum on the shaft, but nothing moove, even if i try to pry them out. Help please !
pg
09-23-2004 02:13:01
 Re: Mc Cormick W12 brake drums in reply to JeanRay, 09-22-2004 21:38:16
the cover comes off with 2 small bolts, the brake drum is held on by one nut. the drum should slide off. if its stuck on, might have to use pb blaster or heat up the drum. have had the same problem. pg
