Tractor Talk Discussion Forum
CHAR-LYN POWER STEERING
FRANK
09-22-2004 08:16:13
I,M INSTSALLING A CHAR-LYN POWER STEERING UNIT ON A SMTA. THIS IS A NEW UNIT THAT WAS PURCHASED FROM THE Y/T WEB SITE. THE UNIT IS COMPLEATE BUT TWO PAGES OF THE INSTALLATION IS MISSING. THE PART THAT SHOWS THE LOCATION OF THE VALVE AND THE ROUTING OF THE HOSES AND FITTINGS. IF ANYONE HAS A COPY OF INSTALLATION INSTRUCTIONS OR CAN TELL ME HOW THEY GO I WOULD APPRECIATE IT VERY MUCH. THANKS, FRANK
jakej
09-22-2004 09:35:22
 Re: CHAR-LYN POWER STEERING in reply to FRANK, 09-22-2004 08:16:13
What type steering vave dis you buy, a torque amplifier or a rotary valve? The amplifier fits in line powered by an auto type pump [1000psi] or a rotary valve which has 4 ports [pressure, return, and 2 ports left&right. This type operates at 2000 psi and the steering column is splined. I have the instalation diagram used by Jackson Power steering. Also post the casting and id plate and I'll attempt to help.
