Tractor Talk Discussion Forum
need help hooking up tri-wing to a oliver 880
ed
06-26-2004 08:16:47
hi folks, here is the problem i have a 880 deisel , looking to buy a rhino tri wing the problem is that i can not get the wings to lift. read the manual it said to install a monentary restrictor swivel assembly..that i did at the left rear in place of the regular free-flow assembly,install a quick connect..and then hooked up the line,,,i forgot to mention the mower has single action cylinder..can any one tell me what step i may be missing ,,or the proper way to hook up for a single ation cyl to get the wings up...thank you in advance ..... ed
Ron
06-26-2004 08:29:09
 Re: need help hooking up tri-wing to a oliver 880 in reply to ed, 06-26-2004 08:16:47
Your 880 Operator's Manual has photos and instructions to set the hydraulic valves for single cylinder operation. It's one of those "a picture is worth a thousand word" deals.
ed
06-26-2004 10:41:14
 Re: Re: need help hooking up tri-wing to a oliver in reply to Ron, 06-26-2004 08:29:09
RON, THE ONLY OPERATORS MANUAL I HAVE IS NO.S1-4-26 AND ON PAGE 10-15 ALL THEY MAKE MENTION IS THE RESTICTOR ASSEMBLY WERE TO HOOK IT UP... AND THAT IS IT..WHAT MANUAL DO YOU HAVE...? THANNK S ED
Ron
06-26-2004 14:35:22
 Re: Re: Re: need help hooking up tri-wing to a oli in reply to ed, 06-26-2004 10:41:14
That's not the one I have. Is there somewhere in yours where it talks about bypass valves?
Another thought. You might want to post on the Oliver forum here. Someone there might have a digital camera and be able to post the valve locations.
