Tractor Talk Discussion Forum
OR 2-stroke engine parts
Davis In SC
05-07-2004 15:20:12
Wondering if anyone knows of a source for O&R (Ohlsen & Rice) parts, especially carb kits. I have 2 of these little engines, one is on a generator, & the other is one that mounts on a bicycle front wheel. I think they were built in the 60's, ..... No luck on any web searches. Thanks & Regards, Davis
Ben uk
05-11-2004 11:58:14
 Re: OR 2-stroke engine parts in reply to Davis In SC, 05-07-2004 15:20:12
loads of parts for smaller 2 stroke engines on www.50cc.nl
Ron
05-07-2004 18:47:20
I have three engines ( O&R ) one is complete with the metal shrouding and gas tank.. I think there ore two carbs..I have not tried to start them, was going to use them on a R?C Aircraft...guess I will not get around to it..!!! Would you be interested in these..???
Ron, in Ohio..
Davis In SC
05-08-2004 16:54:38
 Re: Re: OR 2-stroke engine parts in reply to Ron, 05-07-2004 18:47:20
Thanks for reply, Ron..... The engines I have are all there & mechanically sound, but the carbs need rebuilding. The gas /oil mix has hardened the diaphragms so badly they will not work. I need to do some research to find out what company made carbs, perhaps I could get parts through them. Regards, Davis
Kelvin
05-08-2004 20:39:04
 Re: Re: Re: OR 2-stroke engine parts in reply to Davis In SC, 05-08-2004 16:54:38
If all you need is a carb kit, see if the carb has the maker's name on it and its own model number. Lots of small 2 cycle engines use Walbro carbs. I think 2 other companies made lots of carbs for them too.
You should be able to get a kit through a dealer who uses Rotary or some other aftermarket small engine parts source.
Davis In SC
05-08-2004 21:23:49
 Re: Re: Re: Re: OR 2-stroke engine parts in reply to Kelvin, 05-08-2004 20:39:04
Thanks Kelvin,I should have thought about Walbro... I built several plastic molds for them about 20 years ago...I need to look & see if I can ID them..... Thanks, Regards, Davis
