Tractor Talk Discussion Forum
Massey 135 won't stop
C. A. Griffin
01-12-2004 09:38:36
My M.F. 135 sometime won't stop. I push i the clutch and it keeps going. It does not do this very often. Is the clutch bad?
Bus Driver
01-12-2004 10:00:16
 Re: Massey 135 won't stop in reply to C. A. Griffin, 01-12-2004 09:38:36
I had this happen with another brand of tractor. If linkage adjustment per manufacturers instructions do not cure the problem, it is likely that some parts on the pressure plate have come loose. Splitting the tractor is necessary to repair that. Get it fixed- it is too dangerous as it is.
Alvin n Ms.
01-12-2004 12:07:27
 Re: Re: Massey 135 won't stop in reply to Bus Driver, 01-12-2004 10:00:16
I would apply the brakes, slip the clutch and try to burn the grease and gum off the flywheel and clutch plate. Could be the clutch lining is just sticking to the flywheel. alllllvinnms
Ray,IN
01-12-2004 15:45:27
 Re: Re: Re: Massey 135 won't stop in reply to Alvin n Ms., 01-12-2004 12:07:27
Yep! I also subscribe to the KISS principle. If slipping the clutch(as in up against a large tree)does not free up the clutch the next item is to reset the clutch(s) adjustments to proper specs. The last resort is splitting the tractor to replace the clutch, pressure plate, Throw out bearing, and anything else that appears worn. This in not a difficult job with the proper equipment, but it is time consuming. The entire procedure is detailed in the MF135 shop manual.
