Tractor Talk Discussion Forum
Whats The Difference
Paul
12-17-2003 06:05:55
Went to a local ag supply store for some tractor hyd fluid. They had 3 different brands at 3 prices from $18.00 to $39.00 for 5 gal. They all said they meet the specs for, then listed all the tractors & fluids they replaced. What is the difference other than the price.
Brian G. NY
12-17-2003 12:58:02
 Re: Whats The Difference in reply to Paul, 12-17-2003 06:05:55
I always assumed the stuff called "Hy-Tran" or such is meant to be used in those tractors whose hydraulic system is integrated with their transmission. That fluid would have to properly lubricate gears, clutches and wet brakes as well as provide a fluid for the hydraulics. I buy the "plain ol'" hydraulic fluid for my A-C WD; I assume it is probably superior to the 20W non-detergent motor oil called for in the Owner's manual.
Ben in KY
12-17-2003 09:59:15
I have used the Tractor Supply UTF equivalent for HY-TYAN. 29.00 per 5 gallons, I think. I am satisfied with it, use it in my IH 2444 with both engine mounted and front crank mounted pump, about 30 GPM total flow, No foaming. Pick an oil that meets the specs for your specific tractor.
Nebraska Cowman
12-17-2003 08:36:02
I have had trouble with cheap "farm suply" oil foaming.
