Tractor Talk Discussion Forum
15 foot bushhog
mitchell dabbs
09-23-2003 13:49:30
Hello,
I recently purchased an IH 1066 Turbo Diesel Tractor without T/A. I am going to need a bushhog
for next summer and a 15 foot bushhog is what I really need. Here is my question: Some bushhogs are rated 540 (pto) or something like that..others are less, some are more. What does this mean and what number would be best for my tractor? What is
a good brand to buy and which ones would you stay away from? Thanks, Mitch.
erndog
09-23-2003 19:52:30
 Re: 15 foot bushhog in reply to mitchell dabbs, 09-23-2003 13:49:30
if buying used or new, the Bushhog brand of rotary mowers are pretty hard to beat. they do stand up to the abuse. if you are going to be doing some rough mowing, go with the 1000 pto shaft if you can.
MITCHELL DABBS
09-24-2003 08:24:55
 Re: Re: 15 foot bushhog in reply to erndog, 09-23-2003 19:52:30
MANY THANKS TO ALL THAT RESPONDED! BEST REGARDS, MITCH.
Cliff Neubauer
09-23-2003 19:46:19
third party image
We bought a new JD HX-15 15' flex wing mower this summer that we use on a 1066. The 1,000 rpm pto is the only way to go on a tractor that size as it has too much power for a 540. The hp is not what will tear up the mower drivetrain, torque is and the fast a shaft turns the less torque it has so the 1,000 will hold up much better. We bought a new mower since the used ones we saw were beat to death and weren't much cheaper than new ones. My first choice would have been a Bush Hog, they have the heaviest gear boxes and have a 5 year warranty compared to Deere and Wood's 2 year. I have heard of alot of gear box problems with Woods and they are 1,000 lbs lighter than the Deere. Our Deere does a great job and I've even used it on our back yard with good results. The Deere has a domed deck which is supposed to prevent material from building up on it but as you can see it doesn't make much difference.
wh
09-23-2003 18:18:10
bought a woods bw 180 this spring. LOVE IT!!!! it is a 540 pto with gear boxes for up to 160 horse power. the 540 turns it fine. pulling it with a 75 hores case ih cx90. new one runs about $8000. a model with the 1000 pto would be more. wade
paul
09-23-2003 14:04:24
Gearboxes on the hog are rated for horsepower. Your 1066 is near 135 hp, so you would need a 150-175 hp gearbox I'm sure.
Pto's used to all come in 6 spline, 540 rpm speed. A shaft of that size, at that speed, can olny safely transfer 60-75 hp. Beyond that, it takes very exotic (expensive) metals to make a shaft good enough to handle more hp. So, the 1000rpm pto with 21 finer (I think 21?) splines on it came out, that can handle 200 hp or so. The faster speed & slightly bigger shaft gives allows more hp transfer.
I would expect any good 15' bush hog to need the 1000 rpm pto. Your tractor probably is capible of either speed, but might need a special shaft which may or may not have come with your used tractor. On JD, you pull the shaft out of the tractor & flip it around & put it back in. On Ford, you swap shafts. I'm not toally sure on IH.
Look at your pto, and tell us which style is sticking out?
--->Paul
mitchell dabbs
09-23-2003 16:52:21
 Re: Re: 15 foot bushhog in reply to paul, 09-23-2003 14:04:24
Thank You Paul! Best Regards, Mitch.
