buickandeere
mikeinWA
04-09-2005 11:32:52
Thanks for weighing in on the Canadian Deere issue of mine. Can you verify that this is a Mannheim tractor and offer a blue book. I have been unable to find a site that values used tractors. JD1630 serial#222352, 145 loader, good shape, no smoke, no leaks, 50%rubber, guage shows 4000+ hrs. If we opt to purchase it will be the back bone of the vegetable operation, tilling, brush hog, seeders etc. so it is an important decision for us. Sincere thanks for the help
Mike
Allan/NCA
04-10-2005 14:00:43
 Re: buickandeere in reply to mikeinWA, 04-09-2005 11:32:52
Don't be afraid of of the 55 series they are better tractors than the 2240 series because of the up dates. When they discontinued the some the growers bought everyone they could get because they didn't know how good the 5000 series was going to be. I have a 2355N with 4WD and Hi/Low and its one of the best tractors that I'ver owned or used, I'm looking for another one to replace my 2640 some day. Allan
Gary Myers
04-10-2005 07:20:56
Just for interest sake I've posted a picture in Tractor Photos of a Mannheim built 1630 I saw at a John Deere show yesterday.
buickanddeere
04-09-2005 12:19:17
A Mannheim 1630 looks to be the counterpart of a Dubuque 1530. Both about a 45HP three cylinder diesel. No clue on the "Blue Book" price. If that tractor is complete, intact, not bashed up or "farm engineered". It will sell used for near it's origional new price in Canada. New price for a 1530 in the US was $7145.00US in 1973. Price of grain han't changed much since then either. The 30 series is getting a bit old as production dates back to 1974 to 1975 or so for 1530's. The 1520-1120,1530-1630,2240-1630-1140,2150,2155. Are various generations of the same size Dubuque and Mannhiem tractors. For loader work and working in wet soils. Is there any M4WD tractors in the local market? You could handle the same loads with less ballast and less soil compaction. Pull the transmission oil filter and screen before opening your wallet. If it smells of sulpher it probably had regular 90 or 140 weight gear oil added.To this very day, 45 years after transmission and hydraulics lubes have been combined/common.There are still illiterate know it alls that think "gear lube". There will be or soon will be friction material from the high/low shift and brakes. The pto maybe the two stage dry clutch and would be ok. Check the clutch bearing grease fitting. No grease or great gobs of grease are both a bad sign. Test the coolant for being acidic with a ph test strip. if acidic be prepared to install at the least a fresh set of wet sleeves.
mikeinWA
04-09-2005 15:19:53
 Re: buickandeere in reply to buickanddeere, 04-09-2005 12:19:17
Just as confused as ever. Can you tell by serial# the country of origin? There are 4x4s out there, the 2355s are starting to show up used lately but the price reflects the benafits of four wheel drive. If this where a 2240 I would jump at it but the fact it is from outside the country has me a little on edge. If I knew it was manufactured in Germany that might make a difference to me as well, the German tractors have an excellent reputation around here.
buickanddeere
04-09-2005 22:32:41
 Re: buickandeere in reply to mikeinWA, 04-09-2005 15:19:53
Serial number info. 1st four digits are the model number. 5th digit "A" for collar shift, Q for TSS with MFWD. 6th through 11th digit is the serial number. Last/12th digit is "L" if built in Mannheim. "T" if Dubuque
Engine serial number info. 1st is number of cylinders. 2nd through 4th is the cubic inch diplacement. 5th digit is D if a natural aspirated diesel. 7 & 8th digits is version. "06" used for Mannheim built 2240. 9 through 14 is engine serial number. 15th & 16th digts are CD if built in Saran France. "T" if built in Dubuque. Trans serial number info. Top row is trans serial number. 2nd row is tractor model. 3rd row is Differential Cone point adjustment in millimeters. 4th row is ring & pinion gear count. E.G. 43/9
mikeinWA
04-09-2005 23:59:41
 Re: buickandeere in reply to buickanddeere, 04-09-2005 22:32:41
Wow-now that is some info I can put to work. Where does one learn this? Thank you.
buickanddeere
04-10-2005 07:12:19
 Re: buickandeere in reply to mikeinWA, 04-09-2005 23:59:41
It's genetic. My Mother was driving the 70D standard while she was pregnant. Found that tractor, bought it back and restored it.
