Fordson Tractors Discussion Forum
New Major Valve Tolerances 1953-1958
Mark S.
08-02-2004 20:14:26
My machine shop cannot seem to find the clearances for the valve seats, depth from head of the seat, spring height and so on. Are the FPM and FSM valves interchangeable with the Major? Thanks.
Don Young
08-09-2004 21:03:49
 Re: New Major Valve Tolerances 1953-1958 in reply to Mark S., 08-02-2004 20:14:26
The I&T manual and the parts list indicate that some 1952 and 1953 Majors used valves with different rotator styles but all later ones seem the same. Of course, the diesel and gasoline engine valves are different. Valve seats should be .0045" to .006" larger than the head recess. Standard intake seat OD is 1.8900-1.8905" and thickness is 0.2175-0.2195". Standard exhaust seat OD is 1.7020-1.7025" and thickness is 0.2175-0.2195". Seat width is 3/64-1/16". Valves should not protrude more than .034" from the cylinder head machined surface. If the springs have 8.8 coils they should be 2.48" long and force should be 45-50lbs at 1.98". If they have 7.5 coils they should be 2.31" long and force should be 62-68 lbs at 1.98". Can't find anything on spring installed length.
Hope this helps. Don
