Fordson Tractors Discussion Forum
E27N Throtle linkage
David Ramsay
07-14-2004 12:23:56
I have recently fitted the modified carb and manifold to my E27N. Does anyone know the correct length for the vertical rod that connects the carb to the govenor assembly as I am having problems getting this set. Thanks David
Frank from Australia
07-15-2004 05:51:19
 Re: E27N Throtle linkage in reply to David Ramsay, 07-14-2004 12:23:56
David, I am not sure which manifold and carbie you are refering to, but if it is the latest model fitted on the E27N before they went out of production, the length of the rod on mine is set to 28 cm or 11". I hope this helps.
Regards, Frank.
Countyman2
05-13-2006 14:15:43
 Re: Re: E27N Throtle linkage in reply to Frank from Australia, 07-15-2004 05:51:19
David, Try fitting it with an ajustable rod with a turn buckle in the middle, its only a matter of trial and error to find the setting wanted Fred
