Fordson Tractors Discussion Forum
Advance timing or not?
woogs
07-05-2004 18:29:20
Just put new injectors in my 64 Super Dexta. Cleaned out Air filter and reset timing. Tractor is running but does not have as much power as it used to. When brushoggin she wants to stall out if I try to put her in high gear. Seems to be hunting a bit also. Should I advance the timing a little? I believe it was closer to 30 degrees before I re-timed her.
Thanks,
Woogs
