Fordson Tractors Discussion Forum
Fordson Super Dexta Transmission Problems
Sam W.
06-07-2004 14:42:07
i have been having problems with the transmission in my fordson super dexta. the "H" shifter for the gear selector wears out and needs to be rebuilt with brass about once a year. i just wanted to know if anoyone else has this problem, or if its normal.
any and all input to this is appreciated.
thanks to all
HENRY JOYCE
06-14-2004 06:03:39
 Re: Fordson Super Dexta Transmission Problems in reply to Sam W., 06-07-2004 14:42:07
This is a aproblem with dextas that have done a bit of work. The bottom of the gearstick needs to be built up with braze or weld and then ground back to shape so it fits in nice and snug to the holders on top of the selector.
I f the tractor "sticks in gear" lift of the cover plate and line up the two holders to allow the bottom of the gearstick back in this can be done witha alonghandled screwdriver.
A tip to prevent sticking in gear is to be gentle with gear changes and dont be too rough changing up or down
henry
Burrhead
06-07-2004 17:30:56
yessir it's very normal. I weld instead of braze the shifter ball and it's good to go then for several years
