Fordson Tractors Discussion Forum
Fordson dexta hydraulics
J. Ireland
05-18-2004 06:29:43
I find incredibly excessive play 6-8mm at the pin which connects the piston arm to the the hydraulic lift.
Should the piston arm be bushed to a comfortable fit or is the amount of play necessary?
Majorman
05-18-2004 09:34:54
 Re: Fordson dexta hydraulics in reply to J. Ireland, 05-18-2004 06:29:43
The pin/rod should be loose and floppy so that no strain is applied to the pin when lifting. All the load goes on the ball end. We rebuild them using a good coating of Moly grease before re-assembly.
