Fordson Tractors Discussion Forum
Re: Dextra Cylinder Head
Burrhead
05-07-2004 08:39:02
If I understand correctly what you are talking about is the pre-combustion chamber cover. It is supposed to be there and the plate has nothing to do with being a gas engine.
You can get the cover plate from a bone yard or from Perkins Diesel. Or if you can't find one then a piece of 5/16" steel cut and drilled to fit will work.
All that cover has to do is form a tight seal to the head so that compression is'nt leaking past it.
