Fordson Tractors Discussion Forum
Fordson F Coil Box
Rusty
03-03-2004 15:12:54
The fordson coil box I have has a semicircle on the front of the box as well as the Fordson name and needs a wood back.
Can you tell me where I can get the mounting bracket to the motor and what year this box is?
ADAM
03-03-2004 20:20:16
 Re: Fordson F Coil Box in reply to Rusty, 03-03-2004 15:12:54
what you have is refered to as the "rainbow box" refering to the rainbow like crease on the front of the box. this box should have 4 tabs on the back to mount it to the engine: two on the top that head bolts go thru and two on the side that two studs go thru.
Rusty
03-08-2004 17:41:25
 Re: Re: Fordson F Coil Box in reply to ADAM, 03-03-2004 20:20:16
Adam,Thank you for feed back,i have the steel box with out the wood, there are no support motor
bracket to bolt to the moter,the back does have 4 small tabs to bolt on the wood back. The question is can I obtain this bracket and where? Sorry I didnt explain my problem.THe year is still in question ?
ADAM
03-09-2004 20:09:48
 Re: Re: Re: Fordson F Coil Box in reply to Rusty, 03-08-2004 17:41:25
sounds like someone cut off the mounting tabs. the rainbow and later boxes had mounting tabs that were formed from the box, it was all one unit, two tabs protruding from the top and two from the side. now i have seen several model t coil boxes that were fastened to fordsons. these had four carriage head bolt holes, two on each side to bolt it to the fire wall. you might have a "t" box in your possesion. each way sounds like you need a new box. get some fordson books and study the pictures, to get a box hit the swap meets this spring or try e-bay
