Fordson Tractors Discussion Forum
63 Super Dexta dsl
Charlie
02-24-2004 07:59:49
A friend of mine has just aquired a 1963 Super Dexta dsl, 3 speed hi-lo trans, NO pwr steering, starts & runs (I believe it has a 144 ci Perkins Dsl). It needs some TLC, cleaning, tune up, paint, rear tires etc. He plans to use it for bush hogging and drive way up keep (blade & box blade). What size would be recomeended for this size tractor?? (5-6ft hog, 6- blade, box blade???)
Can any of you help with some of the good & bad points fo this model. Are parts still availible?? What the approx HP?? Any information will be greatly appreciated. Thanks in advance.
Steven B
02-24-2004 19:44:47
 Re: 63 Super Dexta dsl in reply to Charlie, 02-24-2004 07:59:49
Never use ehther, its like crack coccain to those little engines.
Steven B
jim
02-24-2004 18:00:45
Charlie - I bought my "Super" in Nov. of 1963 and still use it. Great little tractor that will easily handle a 5' bush hog and a 7' blade. The engine is basically a 152 cu. in. Perkins that is bullit proof. Just remember to change the oil and filters every 100 hrs.IMPORTANT - also change the oil in the injection pump at the same time - never allow the pump to run dry.
tony
02-25-2004 03:14:37
 Re: Re: 63 Super Dexta dsl in reply to jim, 02-24-2004 18:00:45
charlie, what filters? the only filters I know about is for the oil and fuel. I didn't know there was oil in the injector pump. Tell me more.....
jim
02-25-2004 06:29:18
 Re: Re: Re: 63 Super Dexta dsl in reply to tony, 02-25-2004 03:14:37
Tony - Super Dextas have a Simms injection pump which has its own lubrication oil. On the top,close to the front of the pump,is a plug(15/16"wrench) which is the filler hole.On the side of the pump, you'll find a small, fine threaded bolt which is the oil level plug (1/2"wrench),with a similar bolt(drain)on the bottom of the pump.Drain and top up with the same oil as you're using in the engine. Over the years, there's been a lot of these pumps damaged because this oil level was either ignored or people were not made aware of its importance. Really just another area to service on a regular basis. Those pumps are very dependable as my Super has in excess of 12000hrs and my 5000 with 10000 hrs on Simms pumps.
tony
02-25-2004 12:21:54
 Re: Re: Re: Re: 63 Super Dexta dsl in reply to jim, 02-25-2004 06:29:18
so then do the pneumatic pumps need the same preventative maintainence as well?
jim
02-25-2004 14:28:41
 Re: Re: Re: Re: Re: 63 Super Dexta dsl in reply to tony, 02-25-2004 12:21:54
Pneumatic govenors were never on Supers so I can't comment on their maintenance. I believe the main problem with them was a deteriating internal gasket/diaphram.If you do a search on this site, that problem was addressed some time ago.
paul UK
03-02-2004 12:30:43
 Re: Re: Re: Re: Re: Re: 63 Super Dexta dsl in reply to jim, 02-25-2004 14:28:41
standard Dexta is 39hp super Dexta (1962/63)orange wheel model is 41.5hp suuper Dexta(1963/64)called performance model in UK is 44.5hp
this is the blue/grey super.
