Fordson Tractors Discussion Forum
spoke wheel question
stumped
01-16-2004 18:12:22
Does anyone know if a French & Hecht round spoke wheel, 6.00 - 36" with a 6-bolt center mounting plate was made for any model Fordson? Casting number is HC 126.
Thanks!
ADAM
01-20-2004 11:34:03
 Re: spoke wheel question in reply to stumped, 01-16-2004 18:12:22
The F&H wheel for a Fordson would have a deep cone shaped hole for the wheel wedge with six 3/4 NC bolts holding it in place. The wedge is the same as the 1918-1928 F. Oliver used a wheel,i'm not sure that it was made by F&H, but it looks similar but the hole for the wedge is to big. If you have a wheel with just a plate and six equally spaced holes that would bolt to a hub they are for somthing else. hope this helps, ADAM
stumped
01-21-2004 07:35:26
 Re: Re: spoke wheel question in reply to ADAM, 01-20-2004 11:34:03
Adam,
Thanks much - yes, that apparently eliminates the Fordson F.
Scott
01-17-2004 15:26:46
That size is close to a Fordson rowcrop starting in 1936 but they had a round center for a wedge.
Scott
01-17-2004 15:28:40
 Re: Re: spoke wheel question in reply to Scott, 01-17-2004 15:26:46
The more I think about it they did have 6 bolt holes for the wedge.
stumped
01-17-2004 20:48:18
 Re: Re: Re: spoke wheel question in reply to Scott, 01-17-2004 15:28:40
Scott,
Thanks for the info - any idea what the casting number was on the wheel?
