Fordson Tractors Discussion Forum
serial #
Rick Krausse
01-08-2004 17:20:30
First of all I would like to thank Jerry G. and Ian for helping me with finding the serial #....Thanks Guys....I found it. Now maybe someone can help me date it. The serial # is 1362611 It is a Fordson Major Diesel. Thanks again.
Rick Krausse
01-13-2004 17:26:51
 Re: serial # in reply to Rick Krausse, 01-08-2004 17:20:30
I would really appreciate that, my email address is mediumric57@yahoo.com
Rick Krausse
01-11-2004 16:20:55
Jerry, yes mine has it. Thanks for the help on the engine size. Looking for ideas on an oil bath air breather, a part #, or what will interchange with it, or any other help that you might have. Thanks Rick
Jerry G
01-13-2004 04:38:01
 Re: Re: serial # in reply to Rick Krausse, 01-11-2004 16:20:55
Rick, if you'll post an email address, I can scan a parts blow-up of the intake assembly (with part #'s) for the diesel and email it to you.
Jerry
Jerry G
01-11-2004 06:00:54
Rick, the I&T Manual lists that as being built in October 1955. It's a 220 c.i. engine at 40 hp. Could you check to see if you have a Timing Access cover on the right side rear of the oil pan (kind of an egg shaped swing away plate with a single bolt securing it)? Mine is a '55 FMD assembled in May, and it doesn't have a timing access hole. I think my oil pan has been replaced with one from a later model.
Thanx, Jerry
Rick Krausse
01-10-2004 11:42:48
Thanks Peter, would you by chance no the horse power of it and I am looking for an oil bath breather for it.
Peter, U.K.
01-10-2004 01:49:31
October, 1955.
