Fordson Tractors Discussion Forum
year model
Rick Krausse
01-06-2004 12:36:41
I have recently got my hands on a Fordson Major Diesel tractor. It has a 4 cyl diesel engine. Have looked for the serial # in all the places that I have been told to look and can't seem to find it. Could someone be more specific on the location of it...Thank You
Jerry G.
01-07-2004 04:27:02
 Re: year model in reply to Rick Krausse, 01-06-2004 12:36:41
You've probably already looked here but: If it's and early model, On the left side of the engine, the starter is bolted to the castings. The top of that casting that it is bolted to is flat and about 5/8" wide. On that flat spot, under the dirt, grime, and grease you may find the numbers stamped vertically. They are kind of cursive and may be filled with paint from the factory. I had to scrub at mine with a toothbrush and solvent to really read them well. The 1's and 7's were kinda hard to distinguish. If you find them, post em back and somebody can give you a month/year.
Good Luck, Jerry
Ian
01-07-2004 09:55:13
 Re: Re: year model in reply to Jerry G., 01-07-2004 04:27:02
third party image
bo selecta
try between the battery compartment and the engine
on the firewall whatever its called :]
i didn't realise where mine was cos it was covered in so much dirt it completely obscured the plate ..
