Fordson Tractors Discussion Forum
dexta?fuelpump?looking at a project
Ron
12-22-2003 07:21:07
I've had several fmd but this would be the 1st dextra. It's supposed to run but the injection pump is leaking diesel fuel into the crankcase. I know this can't happen with the fmd. Anyone know if this is an easy fix. I thought that perhaps one or more of the injectors might be leaking down. I can't find anyone who has serviced this type of injection pump. If it's a seal in the pump can it be replaced without sending it out for a rebuild? I havn't seen the machine yet and I don't know the year model of the tractor.
Thanks,
Ron,
New Jersey
tony
12-22-2003 17:52:38
 Re: dexta?fuelpump?looking at a project in reply to Ron, 12-22-2003 07:21:07
Ron,
On The dexta, the crank, cam, and fuel pump are all linked together with a timing gear. This is done inside the front cover of the engine, which is part of the oil sump. It is possibly that the fuel pump could be leaking there causing diesel fuel to containment the oil system.
Tony
