Thanks to both Paul and MIk for the very helpful advice. Today I replaced the sender unit with a new one (cost NZD 16.80 - not bad considering what I could have been up for). There was quite a bit of crud down there and it was a wonder the terminator could conduct any current anyway. The new sender unit has a different terminator in any case so I crimped anew one on - the old sender was probably OK and it just needed the terminator fixing. Paul, I don't seem to have the 8 nuts on the bottom of the sump holding on a round plate. There is one on the front of the engine. I still think it could be worthwhile getting in there and having a bit of a cleanout. Do you think it is worth putting through detergent oil ? I am currently using the New Holland oil for "older tractors". Anyway, thanks again. I will be out the day after Boxing day cutting my hay with it and raking and baling very soon after - still in active service. It's not a pretty picture but I look after the bits that count. When I get time I will fix up the bodywork too Thanks again to you both - if you're ever in NZ I'll buy you a beer Pat
