Fordson Tractors Discussion Forum
Re: Re: FSM 1964 Wish Bone
Bill S.
12-18-2003 19:16:42
Mack, Yes you must remove the front axle stabilizer to drop the oil pan. There will probably be enough oil on the cotter and pin beneath the pan to extract it with reasonable ease. The two bolts thru the front beam may be dry and tight. Patience, penetrant, good wrenches, and as last resort heat, they will come. Knock on wood! Indeed, you have a great deal more ahead but that should answer your question. Bill S.
