Fordson Tractors Discussion Forum
Dry Air Filter for Fordson F
FordsonExchange
10-30-2003 23:33:23
Several years ago I posted a message on the 'Forum' about replacing the floats in the Fordson 'F' Airwasher. I've demonstrated my replacement at numerous shows and have been requested to again post my article. Here it is:
After spending several hours in a national parts store trying to find a suitable replacement for the airwasher float system, I eventually found the perfect fit. It is the Purolator A14650 dry air filter. Originally designed to fit the Saturn automobile, it requires zero modification for precise installation. Remove the Airwasher cover and discard the floats. Clean or sand blast the inside of the cover. I usually prime and paint the inside surface as well. Insert the dry filter into the cap a seal edges with a light bead of silicone. Let set up and replace the cover. P.S. Make sure the air intake on the bottom half of the airwasher is free and clear of any obstructions. Good Luck, Ron@FordsonExchange.com . Please check out my web site under construction and take a peek at my 'F' fitted with F&H wheels and vertical exhaust. I'll be happy to answer any questions about it.
