Fordson Tractors Discussion Forum
Help with Fordson Super Major Throttle
Lute
08-09-2003 10:16:14
Super Major Diesel I inherited starts and runs well at idle, no smoke.
Engine will not rev up to full rpm's. Seems
like it will run up to about one third of
power but still runs smooth.
In other words, advancing the throttle lever past one third results in no increase in rpm's.
Have changed fuel and cleaned fuel filter.
Air filter needs cleaning? Any adjustment to
throttle? Thanks.
ron algiere
08-10-2003 17:39:56
 Re: Help with Fordson Super Major Throttle in reply to Lute, 08-09-2003 10:16:14
1st thing is to make sure that when the lever is at full throttle the linkage is opening the intake all the way. If it is I think the next thing to check would be the timing it sounds like it might be set back a few degrees, but make sure you know the proper setting or you could blow a head gasket.
