Fordson Tractors Discussion Forum
67? Fordson Super Major
NC FSM
07-21-2003 12:24:19
I am looking for suggestions about what I should do to repair this tractor. I have coolant in the oil. I have changed the oil a couple of times but I keep loosing coolant into the motor. I understood from the previous owner that it ran hot one time and he thought that the head gasket was blown. I have tore down to the head garsket and I don’t see any signs of it being compromised. Is it possible that that the head or block is cracked? How will I find a crack like that?
Second symptom is that the crankcase has a lot of pressure on it when the engine is running. It almost seems like the dipstick wants to blow out of the hole. I suspect this is because the vent in the valve cover was obstructed with gunk from the water and oil mixture.
Steven B
07-21-2003 20:15:28
 Re: 67? Fordson Super Major in reply to NC FSM, 07-21-2003 12:24:19
You need to replace the O rings at the top and bottom of the sleeves.
Steven
NC FSM
07-24-2003 07:57:47
 Re: Re: 67? Fordson Super Major in reply to Steven B, 07-21-2003 20:15:28
Very good! Someone else told me the same thing. Next question is I need to get a manual for this tractor. The number behind the injector is 08C965929 can anyone tell me what year this tractor is and what size eng I have?
Steven B
07-25-2003 22:28:37
 Re: Re: Re: 67? Fordson Super Major in reply to NC FSM, 07-24-2003 07:57:47
I am in an airport lounge so I dont have access to my books. You would be safe to say the sleeves you want are 1962 to 1964 Fordson Super Major with O ring at top and bottom. The engine is a Ford 220 CID diesel.
