Fordson Tractors Discussion Forum
1960 Power Major Diesel- clutch seal
Glen Peterson
07-17-2003 08:29:52
Is anyone familiar with replacing the clutch seal in a 1960 Power Major Diesel? This is the seal that is around the shaft that connects the clutch linkage to the transmission clutch shaft. I haven't had much luck finding a shop manual for this tractor that shows and explains replacing this item. Also, would the seal be readily available at a Ford implement dealer?
Any help would be greatly appreciated.
Thanks
Glen Peterson
Cousan
07-19-2003 14:52:56
 Re: 1960 Power Major Diesel- clutch seal in reply to Glen Peterson, 07-17-2003 08:29:52
I have a 64 super major with the same problem. Let me know if you find a simple fix. I think it's a (split the tractor) deal. Does yours have a grease fitting at the clutch shaft? Maybe BURRHEAD knows what it takes. How about it BURRHEAD?
Glen Peterson
07-17-2003 10:02:08
CLARIFICATION -
The problem leakage is coming from under the foot stand where the clutch linkage attaches to the lower part of the transmission. This shaft looks stationary so someone please tell me its not the gasket that splits the tractor.
charles
07-21-2003 04:09:13
 Re: Re: 1960 Power Major Diesel- clutch seal in reply to Glen Peterson, 07-17-2003 10:02:08
You only need to take the wheel off to pull the shaft off. The same shaft carrys both brake and clutch pedals .If you are talking about the gearbox /pto input shaft you will need to split the tractor (easy)
