58 dexta (need help)
David Gillet
05-26-2003 20:37:25
HI all I have a 58 dexta with a problem,It smokes and seams to run a bit rough.I replaced the diaphram because it was surging a little and it had a hole in it.It still surges but only at low idle when its cold,I am not sure but I think its getting to much fuel by the way its running and smoking heavy.Its white smoke coming from exhaust,any info would be helpful thankx David
Paul
05-31-2003 04:57:22
 Re: 58 dexta (need help) in reply to David Gillet , 05-26-2003 20:37:25
A couple of guesses for you..... Try overhauling the air intake. It is an oil over type. Dont just replace the oil,... clean the mesh that is in the cannister above the oil. It takes a bit of time but I noticed a drop in the surging on mine after doing this to her. I used degreaser to flush it out & then a mixture of tapping the unit on a block of wood & compressed air to clean it out. I finished off with petrol flush & air & tapping & then left it in the sun to completely dry before re-installing. The other thing could be your injectors are in need of an overhaul or replacement. Remove them & have them tested.Make sure there isnt a vacuum leak on the pipe work to the intake manifold. Good luck. Let Us know how you get on.
