Dexta steering
Lloyd otto
05-06-2003 16:34:54
I am starting to restore 61 dexta
I want to start with the play in the steering
wheel. can anybody give any detailed info on this
problem
thank you in advance.
Lloyd
Dave
05-08-2003 04:53:31
 Re: dexta steering in reply to Lloyd otto, 05-06-2003 16:34:54
Lloyd - I did some work on a Dexta a while back and I seem to remember that in addition to the shims Burrhead mentions, I think the bearings in the steering column can be adjusted with shims to reduce some of the freeplay there as well.
Burrhead
05-08-2003 18:45:56
 Re: Re: dexta steering in reply to Dave, 05-08-2003 04:53:31
yessir there are shims on top of the top column bearing.
Burrhead
05-06-2003 19:42:19
Lloyd you can take the left side of the steering box off and remove a shim or 2 to take slack out of the steering gearbox.
Just remember when you take the gearbox apart those are not gaskets under the side plate, that is the shims that adjust the box.
If the rocker shaft knobs are worn down you can weld and grind them back down to get the right fit into the steering colum shaft.
capbuster
05-09-2003 22:27:24
 Re: Re: dexta steering in reply to Burrhead, 05-06-2003 19:42:19
Hey Burrhead it's good to see you on the boards again. I hope your boy got alright.
Capp
Burrhead
05-13-2003 20:32:42
 Re: Re: Re: dexta steering in reply to capbuster, 05-09-2003 22:27:24
Hello Capp. The boy is on the mend. I don't check my puter much lately.
Hope all is well and them floods I keep seeing on the weather channel have'nt washed you away.
lloyd
05-14-2003 19:33:05
 Re: Re: Re: Re: dexta steering in reply to Burrhead, 05-13-2003 20:32:42
thanks for the responses about the steering
problem.
i haven't had a chance to work on it yet.
might be a couple of weeks or so depends on weather. thanks again
lloyd
