Re: Fordson Dexta Diesel Tractor HELP!!
Peter, U.K.
05-03-2003 08:06:07
Follow the follopwing sequence;-
1. Make sure small tap on induction primer on inlet manifold is open.
2. Insert key, turn on ignition. The red charge light and the green oil pressure light should come on.
3. Move throttle to half open position.
4. Press down heater plug button and keep pressed for 20 seconds. this button is the lower of the two on the right hand side of the tacho.
5. After 40 seconds pump the induction primer on the fuel tap a couple of times whilst pressing down the start lever. The engine should now fire.
Peter.
