Dexta P T O
David G
03-23-2003 17:42:13
HI all I have a 58 dexta,when I try to engage the pto it will not engage,it seems as though the cluch isn't disengaging it to allow it to.It just grinds and I have to start it with it engaged.What could be the problem cluch works fine on trans.Also I noticed oil dripping from a hole on the bottom front of the trans any Idea where its from thanks David
jim
03-24-2003 15:27:54
 Re: dexta P T O in reply to David G, 03-23-2003 17:42:13
I forgot the oil drip problem. I believe you'll find this is just a drain hole.
jim
03-24-2003 15:24:15
As Damon said, if you have a two stage clutch, you'll find a two-holed clevis at the end of the clutch rod, where it goes into the casting. The first hole engages the first clutch (transmision)
while the second hole engages the second clutch which controls the pto. You'll also find that, in this position, the clutch pedal is raised a lot higher.
Damon
03-23-2003 22:10:30
David,
you sound like you have a two stage clutch, thus providing Live PTO. It sounds like you need to adjust your PTO clutch. I am sure others on the board can provide practical assistance to the correct adjustment.
Regards,
Damon
