Re: Overheating Gas Dexta (1961)
Oscar
11-22-1999 04:08:36
Sounds like trapped air to me. In addition, it could be that the spring in your coolant cap doesn't work like it should. That spring should block the overflow unless the pressure in the cooling system reaches a critical level. I'd advise you to check the spring first. Then, I'd add as much coolant as you can get in there and leave the tractor to stand for the night with the cap off. Any trapped air should slowly evacuate over night. Add more coolant the next day to compensate for the dropped level during the night. Fit a proper, well-functioning cap and try again. Good luck!
