Ron I'm not familiar with the 295 at all. I'm just thinking out loud so please bear with me. There has to be somewhere that inducts air thru a carb. Maybe by taking the clean air duct from the air cleaner and put water thru there. If it's and updraft carb it will still suck the water in. Paddy the water works extremely well on diesel engines that idle alot. Mack, Cummins, and Detroits even if they have turbo. It might would screw up something on the newer air to air systems but for regular diesels without the air to air induction it works fine. If you flush an old style 6.9 or 7.3 non-turbo Ford pickup wait til dark and load a tractor up on a lowboy and shower down on the pickup when ye get up in high gear. It'll start throwing sparks out the tail pipes that look like sparkler fireworks. I have'nt tried it on the newer air to air systems because I would be afraid the water could mess up the oxygen and/or heat sensors in the air cooler.
