Re: Re: Blue Smoke
Burrhead
02-10-2003 00:10:18
thanks for the vote Capp.
Could be just be an injector or 2 not spraying right.
It will still crank good and will run smooth as a glass of water and may still need the injectors cleaned.
Howard Neil
02-10-2003 00:57:45
 Re: Re: Re: Blue Smoke in reply to Burrhead, 02-10-2003 00:10:18
Thanks Capp and Burrhead, that info is a great relief. The tractor gets very little usage normally so I will try to give it a longer run.
It sounds a good idea to clean the injectors. Is this something I can do myself or do I have to send them to an engineer?
On a separate point, I notice that there seems to be a hole for a starting handle. I do not possess one but is it really feasible to start a diesel engine on the handle or is the hole provided for petrol versions?
Thanks, once again, for all the help.
Regards
Howard Neil
WayneB
02-10-2003 03:49:24
 Re: Re: Re: Re: Blue Smoke in reply to Howard Neil, 02-10-2003 00:57:45
I think you are refering to the hole in cowl at front.
A loader-drive-shaft would slide thru that hole, thru the pivot pin and insert in a drive flange on the harmonic balancer. Live pump drive.
Wayne
Paddy
02-11-2003 05:27:54
 Re: Re: Re: Re: Re: Blue Smoke in reply to WayneB, 02-10-2003 03:49:24
U wont start it on the handle without a decompression lever to lift the valves off their seats. Injectors have to be cleaned by professionals, do not attempt it yourself as u will just ruin them.
Burrhead
02-10-2003 10:28:50
Wayne is right on the hole.
The injectors have to be cleaned and then adjusted to the correct snap pressure.
Howard Neil
02-10-2003 14:27:37
 Re: Re: Re: Re: Re: Re: Blue Smoke in reply to Burrhead, 02-10-2003 10:28:50
Thanks to Wayne and Burrhead for this information. It is a bit of a relief to hear that the hole is not for a starting handle. :-)
Although I usually like to do repairs myself, I do not know how to adjust the injectors so I will seek out a local engineer who I can take the injectors to.
Perhaps it will start better, as well, with the injectors sorted out.
Regards
Howard Neil
john
02-12-2003 08:52:38
 Re: Re: Re: Re: Re: Re: Re: Blue Smoke in reply to Howard Neil, 02-10-2003 14:27:37
Actually, there is a hole for a starting handle on a Dexta. My dad once had a diesel Fordson Dexta and only thing that's left of it (he sold it in late 1970's) is the starting handle whitch came with the tractor.
Howard Neil
02-12-2003 10:46:09
 Re: Re: Re: Re: Re: Re: Re: Re: Blue Smoke in reply to john, 02-12-2003 08:52:38
John,
Interesting. The hole in my Dexta certainly looks like a hole for a starting handle and I had really assumed that it was there for a petrol engined version. However, other posts had convinced me that it had other uses.
Mind you, if Capp expects me to go bear wrestling, I think I will stick to the starter motor. :-)
Regards
Howard Neil
Howard Neil
02-12-2003 10:46:07
John,
Regards
Howard Neil
Burrhead
02-10-2003 18:19:12
LMAO--yeah if you can hand crank a Dexta I sure don't want to arm wrestle or shake hands with you.
Capp
02-10-2003 19:57:51
 Re: Re: Re: Re: Re: Re: Re: Re: Blue Smoke in reply to Burrhead, 02-10-2003 18:19:12
I'll amen that Burrhead, if he can do that he probably can go bear hunting with a swith. Huh.
Capp
