Super Dexta Tractor- Lift/PTO Quit
Zayne
11-14-2002 13:04:18
I have a super dexta that was working fine then the lift and pto just quit working. I checked and added rear end fluid but not sure what else to do. It did work again the following day, but just for a few minutes. Does anyone have any ideas where to start troubleshooting or what might be the problem.
Thanks
Burrhead
11-14-2002 16:24:02
 Re: Super Dexta Tractor- Lift/PTO Quit in reply to Zayne, 11-14-2002 13:04:18
sounds like either the spline stripped on the pto shaft or the clutch.
Paul
11-15-2002 04:01:21
 Re: Re: Super Dexta Tractor- Lift/PTO Quit in reply to Burrhead, 11-14-2002 16:24:02
If there was no noise to signal a stripped gear, maybe the pump intake filter is choked...then again that doesnt explain the pto stoppng....hmmm...need to think more ....
Zayne
12-02-2002 16:01:51
 Re: Re: Re: Super Dexta Tractor- Lift/PTO Quit in reply to Paul, 11-15-2002 04:01:21
OK, turns out after taking it into the shop that the problem is the "Sprag Clutch". ONly problem now is the ford house does not know where to get a replacement. ANy ideas?
