Fordson water leak
Tad
11-06-2002 20:19:03
I am loking at Fordson Major diesle and noticed a small antifreez leak around the throtle likage that goes through block to the injector pump. Does this mean I have a bad block? or need some sort of seal.
Heli
11-08-2002 15:47:24
 Re: Fordson water leak in reply to Tad, 11-06-2002 20:19:03
The most common cause tor a leak at the throttle control crossrod is a cracked block. I had one with the same problem. If the crack does not go throught to the crank journal you should be able to have the cross rod hole sleeved by a machiniest.
Hope this helps.
