Re: Starter for a 58 Dexta.
Paul
11-02-2002 18:03:52
Cant really help you with the info your after, however i'm wondering if your starter is really in need of replacing. I thought mine was gone just recently & actually found I just needed to scape out the division lines on the commutator & replaced a brush spring & it was fine. If you have a Dexta manual ( I&T )it shows how to adjust the switch. The other thing I did was to replace or clean to a sparkling finish each and every electrical connection associated with the starter, and that includes the solinoid. Actually I pulled the solinoid off & cleaned the body where it contacts the frame & installed an earth wire from there to the wiring harness main earth just below it. Made all the difference in the world. I thought I was up for several hundred dollars for a replacement one & it turned out to be just elbow grease & some electrical connections. Just a thought for you anyway...
cheers.....Paul....8^)
