HELP! Tough Shifting on Model F
Ron
10-31-2002 06:26:03
My Model F is tough to get into gear. Lot of grinding (a lot) and I almost have to jam it into gear (yes, clutch is fully pushed down and I idle the engine back). Have been told this is normal with an oil bath clutch and the shifting will become easier with use. Have not had the opportunity to drive it a lot, so it's hard for me to judge the accuracy of that claim. Is this true or do I have a problem? The current grinding when I attempt to put it into gear really bothers me and makes me think I'm a shift away from doing some real damage.
23F
10-31-2002 15:46:10
 Re: HELP! Tough Shifting on Model F in reply to Ron, 10-31-2002 06:26:03
I had the same problem with mine. I pulled the steering gear off and repaired all of the wear points on the release linkage. This solved my problem, and it now shifts much more smoothly.
Ron
10-31-2002 18:18:33
 Re: Re: HELP! Tough Shifting on Model F in reply to 23F, 10-31-2002 15:46:10
How tough is the release linkage to get to (assume you mean the clutch release linkage)? How did you recognize and repair the wear points. Looked in my manuals for the connection between the steering gear and the release linkage and couldn't find it. Am a new Model F owner so please forgive the questions if they are dumb
Ron
10-31-2002 18:18:21
23F
11-01-2002 04:17:48
 Re: Re: Re: HELP! Tough Shifting on Model F in reply to Ron, 10-31-2002 18:18:21
I just sent you an e-mail to try to explain what I did.
Ron
10-31-2002 07:30:11
As a follow-up (I've been reading archived material from this forum on the subject): the tractor does stop when the clutch is pressed.
