Changing engine in my fordson
Scott Atkinson
10-01-2002 06:13:52
I have a fordson power major/engine with a cracked block, the only #s I can find on the engines are as follows....cracked block 1484307 and K19B. #s on the new block I bought...S705434 and C23A. Both are 4 cyl. diesel and everything seems to match up external, but before I start tearing it down and trying to switch internal parts I would like to know will it match up? and why cant I match these serial #s from the ones I see on the net? I believe the first engine is Aug. 19 1958
Heli
10-23-2002 19:03:00
 Re: changing engine in my fordson in reply to Scott Atkinson, 10-01-2002 06:13:52
The new block you have was made in '62, but don't quote me on it. The differences in the block are that the new block takes larger OD sleeves. You will need to find the larger sleeves to fit the block. I ended up making them myself because I couldn't find sleeves alone. Everyone wants to sell them with the pistons. New pistons would have been nice but the new pistons would have the 1-3/8 wrist pin. My rods are the 1-1/4 inch wrist pins.
You should be good to go once you locate a set of sleeves.
Best of luck,
Heli
