The prize of the brake shaft oil seals for FMD
TH
09-12-2002 23:19:52
How much does the brake shaft oil seals for Fordson Major Diesel cost? I mean the axle where the brake drum in attached. There are two seals: inner and outer seal. I live in Finland and they say that the seals cost 50 euros each (= 49 USD). That is quite high.
Do you know where I might be able to purchase those seals (by mail order) for example in Great Britain? I was told that they cost a lot less in there.
All help will be appreciated.
TH
christer
09-14-2002 23:46:42
 Re: The prize of the brake shaft oil seals for FMD in reply to TH, 09-12-2002 23:19:52
Hi
Here in sweden we can buy it from olsson i ellös for 159 S.kr.
Regards Christer
Peter, U.K.
09-13-2002 00:26:57
Take the old oil seal to a dealer who specialises in bearings and oil seals. You should find one in Yellow Pages (or the Finnish equivalent) Each seal and bearing has a number from which your specialist should be able to supply a new replacement. Whatever you do don't go to a main dealer, he will charge you ten times the price of the specialist for the same seal. If you have no luck, e-mail me and I'll get them from here in the U.K.
Regards,
Peter
