Re: Fordson Major Diesel water in engine oil
Steven B
08-07-2002 04:53:12
Mark
It is almost always the sleeves leaking. They can be removed with the engine in frame. Remove the front axle wishbone then the sump (there is a sump bolt up in a groove at the front of the engine near the pully, dont forget to remove it). Also remove the oil pump.
You will need a sleeve puller. I had mine made at the local machine shop. Get a piece of round stock machined 1/2 in thick about 105mm in diam with a 97mm step and a 1in hole. This goes in the bottom of the sleeve. You will need 1in diam threaded rod and a piece of inch thick steel to make a bridge with a 1in hole in it. Be carfull not to hit the crank when you insert the steel rod. With a nut on the bottom abd one on the top, the steel bridge with blocks of wood bridging the cylinders, get a big spanner and a piece of pipe as an extension and pull em out. Be aware they take some shifting. I usualy wrap the crank journal with a rag. I have had to use a six foot pipe as an extension to shift em in the last engine I did but usualy they are not that bad.
You may need to replace the sleces as electrolysis eats em away at the bottom. I would at least also replace the rings and bearings.
Good luck
Stevn
