Sos
josh
07-15-2002 11:52:23
trans stick shows me time to chnge oil its
wht i put in it? how much?
were is fill hole?
super majour 1961.
Majorman
07-15-2002 13:06:26
 Re: sos in reply to josh, 07-15-2002 11:52:23
Try>Link
Good Luck
Steven B
07-16-2002 15:51:48
 Re: Re: sos in reply to Majorman, 07-15-2002 13:06:26
The stick indacates the oil in the rear end. Takes about 9 and a 1/2 gallons of 30w or better yet, universal tractor oil. The filler is behind the seat near the uper lift arms on the right hand side. The trans takes the same oil, the filler is near the clutch pedal on the side of the transmission. This holds 6 gallons and you fill it to the level indicated near the plug.
The older books tell you to use 90w oil but this was changed later. You can use 90w but universal oil is also ok.
Steven B
oh oh
07-16-2002 22:22:09
 Re: Re: Re: sos in reply to Steven B, 07-16-2002 15:51:48
in the plug goes hd/trans oil
added some.
but trans is gear oil.85/140
will these mix?
Steven B
07-17-2002 02:01:40
 Re: Re: Re: Re: sos in reply to oh oh, 07-16-2002 22:22:09
Should be ok. I think they changed to 30w on later tractors because 90w was to thick for use with remotes. Trans oil can tend to leak down into rear axle as well, watch for this. You will see level on rear axle rise and trans lower.
