Re: major deisel pump
Bill in NC
06-18-2002 14:20:47
Mike
It will depend upon tractor model. wheather it's early or late model. No. 1 piston is coming up on compression stroke. I removed oil filler cap and looked at rocker arm action. Then turning engine slowly until the the notch in rear flange of crankshaft pulley is aligned with pointer attached to engine front plate. On early models, you will find this mark on the pulleys, on later models, the timing mark is on the fly wheel. You will find a cover held by one bolt. Repeat rotating engine until you can see the mark, it should be 23 degrees. E-mail me if you have any other questions @ w1long@hotmail.com. Good luck, Bill
