Brian and capbuster
Burrhead
06-10-2002 19:46:54
Here's a pic of the dexta axle. Brian if you have the retainer like is this pix #8 item you drill 2 each 1/4" holes 180 degrees apart through the retainer ring and burst the retainer off. If you try to press the bearing off sometimes the bearing will ruin before it will press off.
If it does'nt have the item #8 retainer it will have a lock nut in the place of it. The nut is on the later production models and the lock ring is early production models.
