Dexta engine runs unevenly
DaveW
06-02-2002 13:48:15
The engine in my '59 diesel dexta won't run smoothly (pneumatic governer).
Starting from cold, the engine 'hunts' around the rpm demanded on the throttle. In other words, the rpm rises and falls over a period of about four seconds, then repeats the cycle. When the engine is warm, it is less noticable, but still present.
The exhaust smokes a bit but the engine doesn't blow too heavily through the breather pipe. We have cleaned/ replaced all the filters and the diaphram in the governer is in good condition.
Any ideas what could be the cause?
Henning Thomssen
06-02-2002 18:44:57
 Re: Dexta engine runs unevenly in reply to DaveW, 06-02-2002 13:48:15
On the side of the Governor is a plug with a gauze type filter in it,did you clean that?Also,if the idle speed is set too low,it tends to do that sort of thing.
DaveW
06-03-2002 11:47:54
 Re: Re: Dexta engine runs unevenly in reply to Henning Thomssen, 06-02-2002 18:44:57
Yes, we cleaned the gauze filter. The problem is more apparent at low rpm, but even at high rpm it is still present.
Any other thoughts?
Burrhead
06-04-2002 08:25:50
 Re: Re: Re: Dexta engine runs unevenly in reply to DaveW, 06-03-2002 11:47:54
Dave one other small thing- did you clean and make sure the butterfly in the intake is loose and moving without binding. It only takes a small amount of friction on the butterfly for it throw off the governor, or perhaps a small pinhole in the line to the pump from the manifold.
DaveW
06-04-2002 13:01:35
 Re: Re: Re: Re: Dexta engine runs unevenly in reply to Burrhead, 06-04-2002 08:25:50
Thanks,
We did clean the butterfly valve, so all the connections have been disturbed. I will give it and the connecting pipe a check.
DaveW
