Super Major head gasket change info
Pierre
05-27-2002 20:10:30
Now that I found the year & model of my tractor (thanks to Bill & Mark), I need to get the step by step information to perform myself the headgasket change, to fix the leak on my 1963. The head is visualy leaking from the outside of the joint between head & base of motor. Also, it smoke white when the engine starts until it is warm. It is bubbling from the surface of the radiator liquid surface.
Anyone can suggest me where I can get the precious info to perform a headgasket change & is it a big task for someone who never performed it but is comfortable in manual work ?
Thanks.
Pierre
(Qc) Canada
Bill in NC
05-30-2002 16:20:29
 Re: Super Major head gasket change info in reply to Pierre, 05-27-2002 20:10:30
Hi Pierre Get the I&T shop service manual it well give you the step by step information you well need. If you have anty trobl then email me.good luck
jim k
05-30-2002 17:20:24
 Re: Re: Super Major head gasket change info in reply to Bill in NC, 05-30-2002 16:20:29
Make shure you get the right gasket thereis 2 or 3 diferent thicknesses the wrong one and it wount run worth a darn im haveing a problem with mine rightnow GOOD LUCK
