Smoking FPM What could be the problem?
Shane
03-13-2002 16:19:56
I have a Fordson Power Major diesel that smokes pretty badly on start up but once it has been running for a while it cleans up. When it is idling it has a little bit of smoke regardless of how warm or how long it has been running. It does not use a lot of oil, in fact I only top it up once a year. What I would like to know is if this is a sign of glazed bores or some injector timing required or maybe something else. Thanks in advance.
L. Harver
03-14-2002 06:44:49
 Re: Smoking FPM What could be the problem? in reply to Shane, 03-13-2002 16:19:56
A little bit of smoke at idle is normal. These tractors were meant to work not to sit there just idlin.
FMD
03-13-2002 22:13:38
What color is the smoke?
FMD
03-18-2002 06:53:04
 Re: Re: Smoking FPM What could be the problem? in reply to FMD, 03-13-2002 22:13:38
Normally white or grey smoke means, that there´s water in the waste gas. Could be caused by crack in the block or head or by a shot head gasket.
Did you check coolant and engineoil, if there´s oil or water in it?
Shane
03-17-2002 14:04:10
The colour of the smoke is mainly white/ grey.
03-26-2002 14:54:17
 Re: Re: Re: Smoking FPM What could be the problem? in reply to Shane, 03-17-2002 14:04:10
NO IT'S NOT
